Sun Valley SV-310 Preamp
The SV-310 is the pinnacle of our preamplifiers.
It uses the famous Western Electric 310A tube in a non-feedback triode connection, and has a gain of 10dB, making it the most user-friendly design, matching any vacuum tube power amplifier.
In addition, the 600Ω output transformer specially ordered by Hashimoto Electric ensures a constant output impedance over a wide range and across the entire frequency range, ensuring an extremely stable tone with no increase in output impedance in the low range.
Enjoy the appropriate warmth and the best balance between fundamental and overtones to your heart's content.
Its design is like a power amplifier. Its sound far surpasses that of conventional vacuum tube preamplifiers.
Regardless of the excellent sound quality, it has a luxurious output transformer made to order by Hashimoto Electric, achieving the right temperature and the best balance of fundamental and overtones.
The gain is 10dB, making it the easiest to use design for not only the SV-128ii but also other power amplifiers.
Type: Transformer output preamplifier
* All transformers used are manufactured by Hashimoto Electric
Input: 4 line inputs (no phono input) with volume (dual)
Wiring method: All manual point to point wiring
tubes used: 310A*2, 274B*1
*The photo shows Western Electric 310A and Linlai WE274B,
Frequency response: 15Hz-135kHz (1V 10KΩ -3dB)
Gain: 10dB
Dimensions (mm) (including protrusions and tubes): W330×D280×H210
Weight : 12kg
Reactions: 1MOR and CohibaJoe
