My Sumo Theorem is 110 volts. Anyone know how to change it to 240 volts? There are 3 jumpers near the transformer that may do it, but what should they be changed to?
This time I have attached a picture - not great, but you can see the 3 jumpers connecting 6 of the 9 pins right in the middle, between the mains fuse and the transformer. Very grateful for any replies.
Picture not attached.
I deleted my suggestion upon re-reading your comment as I realized that there is not enough information to make a recommendation.
You need to find a trustworthy technician to determine whether or not this Sumo has a dual primaries and can be reconfigured for 230V operation.
Most US designed products that will operate on 230V have either 4 or 6 hole link set ups with two links used for 120V operation and one link used for 230V operation. Your setup sounds substantially different.
