Summing and Lowpass active filter for LM3886, this OP-AMP correct?
Not really.
U2 & U3 - why are you summing the output back in?
U3 & U4 - may lead to instability as you are asking for less than unity gain as frequency rises, also the response will be droopy and to make a 2nd-order active filter there are proper ways that only require one op-amp.
Take a look at the sub-woofer controller project on my website, it is exactly what you need.
A MFB filter will allow both low pass and summing of multiple inputs with just one opamp.
You can use an inverting summing opamp and a Sallen & Key unity gain filter requiring 2 opamps.
You can also use an inverting summing opamp and a Sallen & Key equal component value filter again requiring 2 opamps.
