Hello all,
Below is a link to a pdf schematic file.
http://blu_dot.tripod.com/pdf/schematic.pdf
I am considering buidling an 5.1 PGA2310/PIC controlled pre-amp.
Question however is, will i build all channels on 1 PCB or
make separte boards as can be seen
http://blu_dot.tripod.com/pdf/top.pdf
http://blu_dot.tripod.com/pdf/bottom.pdf
And waht do you think of the PCB setup at all ???
grtz
Simon
P.S. The links do not work. When i cut and paste them in to the address field i get the files after all. Any idea ?
grtz
Simon
