Suggestions for small full range speakers for my Den?
That should work well with an 8 watt/channel amp. However, the reviews mention a bright top end and lean bottom end more than once. I've not heard one, so I can't say either way.
For the same price, you could pick up the Mark Audio Alpair 10-
https://www.madisoundspeakerstore.c.../markaudio-alpair-10-grey-6-full-range-gen-2/
Just my 2 cents. Either way, have fun!!! 🙂
Mike
I'm leaning pretty hard towards the Golden Ratios and the Mark 7 driver
It should fit my available space and the speakers are only about 3 feet away
I'm working on a 2-way with the Satori MW13P-8 and during measurements and initial listening, I realized this driver would make a great full range with no EQ necessary in the right circumstance. It produces unbelievable bass in my ported prototype box - 12" x 6.5" x 12" and has a very flat FR with rising response in the top octave. If used on a desktop, the need for BSC would be negated and the listener should be perfectly off axis to flatten out the rising top end.
I'm a multi-way guy through and through, so I have to add a tweeter up top, but I suspect some full-range guys will start using this gem pretty soon.
Dan
