please suggest me a 4" woofer for two way with very good performance.
the the will be d9700.
what do you think about sb acoustic ?SB Acoustics :: 4? SB12NRX25-4
for example in comparison wieh seas ca12rcy ?
Both are good woofers. I'd go for the one with the best price.![]()
ok, but the seas seems to be less excusion then sb...if you see the suspention the seas is little, the sb is very large...
We have been using the Peerless 830870 with good results.
dave
very good midwoofer, but for two way no goes well into the bass
One thing I'd also do is look for an 8 ohm nominal woofer. The SEAS driver is 8 ohm.
We are using it for its bass capabilities. Needs a fairly large enclosure thou.
dave
also 4 ohm option is good
visaton TI100 looks like a good driver, but maybe not the greatest value.
That SB driver looks quite nice. The visaton (when ive considered them) are pricy. Alternatively, what about something like JX92?
Dayton Audio DS115-8 4" Designer Series Woofer 295-424
another one.
do you have constraints in volume?
another one.
There are a number of drivers out there that would all be excellent choices, at a number of price points and with a number of different cone materials.
The first place to look, in my opinion, for great performance at a low price would be the Dayton Reference line, the RS125 is a very capable driver if you don't mind the metal cone and are good at xover work.
As P10 mentions above, you've also got the entire 4" HDS range from Peerless. These come in a variety of cone materials, glass fibre, aluminium, coated paper and poly. All of these come with decent motors that include shorting rings and have their own benefits and drawbacks.
Next to the Peerless HDS range you've got the Peerless NE/Platinum line, these used to be the Vifa NE line and are still listed as such at a variety of vendors. These posses very nice motors and reasonably well designed cones. I don't think I've read one person say anything bad about them except that as the cones have some resonance/breakup issues, they could be harder to work with than other soft cone drivers.
Other contenders would be the L12, CA12, W12 drivers from SEAS, although these don't quite offer the same price/performance of some of the other drivers already mentioned. The motors of the L12 and the CA12 aren't up to the standard of the other drivers I've mentioned, the W12 is, but it is very expensive for what you get.
From my point of view what this basically boils down to is how capable you are with regards to designing crossovers. If you've got the ability to control any of the drivers here then I would first go with the RS125 if you need something inexpensive. If you'd rather spend a little more then I would personally go with the 4" from the NE line.
The MCM 55-3870 looks very nice, it is a 5" though at $18 it's quite reasonable.
It looks to perform well in a 7L box tuned to 60hz.
another one.
+1 I used it for an MTM enclosure for my brother, and I really liked it's performance, way exceeds it's price.
Though I have not used, the aluminum DA115-8 looks promising.
My experience with Audax has always been good, don't know if they still are, but they supply PSB. The Audax HM100C0 might be a good option.
Possibly:
Tang Band, W4-1720
The Madisound Speaker Store
Vifa, NE123W-04
Wavecor, W120BD04
https://www.solen.ca/pub/index.php?...4&niveau1=&niveau2=&niveau3=&s1=1&s2=&s3=&s4=
My vote is for the 12MU, as it will do what you want. It's expensive, it's a Scan. The tweeter you have is excellent, and can xover LOW. I used mine to 1750 Hz with an 8" carbon Fiber driver.
Agreed at the thought of having good xover chops- you'll want them.
Wolf
Tang Band, W4-1720
Vifa, NE123W-04
Wavecor, W120BD04
Wolf
- Suggestions for 4" Woofer for two way
