hi everyone, I wanted to ask you for the volume to use for a speaker. the woofer is a seas ca18rly in a reflex box(vas 32L, qts 0.47, fs 42Hz). now I have it in a 16L box, I think it's a bit small. thanks.
The speaker specs are here ... SEAS Prestige CA18RLY (H1217) 7" Coated Paper Cone Woofer
Yeah that box is going to be too small. It will work but not well.
Tuned to 35Hz a ported 56L box models the best, but anything between 50 and 60L will work in that region.
And if you want it sealed, half that size will work best (wich is 25-30L) for an FS in the mid 30's
these 16L speakers were sealed, but they had no bass, so I then created a reflex.
You say 50L, while The link above Says from 21 to 28L.
Why this differences?
They tune it higher, their box is tuned ar an f3 of 47hz, mine at 35hz. Tuning it lower means a bigger box. So their box is smaller, but has a less deep bass than i have.
Ok thanks, but the tuning frequency shouldn’ t be +/- 10% of The woofer resonance frequency ?
Not nesesairy, it can be more off sometimes, depending on the woofer. Here they say in the specs that it can be from 35hz so that was the tuning i took. 30 hz would be too low altough...
ok Thanks, could you explain A thing to me?
if the tuning frequency can be lowered by Increasing the length of the tube, what is the need to change the volume of the Box?
that is, with 16L if I increase the tube to get tuning at 30hz, is it the same thing as having a box of 50L with a shorter tube tuned to 30hz?
16 litres vented or sealed is a poor solution. I would suggest 35 litres vented one, tuned to 40 Hz (2" by 2.8") giving you F3/F6/F10=38/34/30Hz.
No, above the port tuning the box behaves mostly like a sealed enclosure, so if your port is tuned low, you need to make sure that the frequencies above also are present, so you need a bigger box to be flat to the port tuning to simplify the theory. Download winisd or hornresp (the former is simpler to use, the latter is more complex) to simulate yourself. You will see if you make the box too small for a tuned port, the frequency plot will not be flat.
If you want a small box, ported or sealed, you will have to tune it higher. If you want it lower, the box will be bigger. If you tune the port too low for the box volume, you will have a peaky uneven response wich translate in a one note sub.
To the OP, it may help to understand that you are conceptualizing only in terms of 3 variables - Vb (the volume of the box), Fb ( the tuning frequency of the box) and port length whereas you actually need to add at least 1 more variable, port SPL or loudness, to fully understand the relationships at work here in a bass reflex enclosure. (I'm ignoring port diameter and box stuffing for simplicity's sake.)
So for example in your case if you keep Vb the same but increase port length, Fb will indeed be lowered but so too will port SPL. Now if you increase port length and increase Vb, Fb will again go down but port SPL will now increase as well. Or in other words, if you want the bass to be both lower and louder, you have to increase both the size of the box and the length of the port. Keeping the box size the same and increasing the port length will lower the tuning but it will also lower the port SPL as well.
As mentioned above, there is no substitute for playing around with a box simulation program to really get a feel for how all the variables interact.
Now if you don't want to build a new box at present, try a port between about 12.5 to 15.5cm long with a 5cm diameter - Fb is around 50Hz, F3 around 55Hz and the FR is fairly flat with small peaking around about 104Hz when the box is heavily stuffed.
ok but always relative to the volume?
with 42L for a 38hz tuning frequency I need a 6.4cm x 10cm tube
while in 16L to have it of 60hz I need a longer tube (14cm). quite right?
Yes, relative. All the variables work relative to the others.
I hesitated to write that 1st sentence (above in your quote) because it could possibly be misleading. The larger box has a lower tuning but also a shorter port? But that is correct in your example as long as the port diameters are the same. In my example, I was using 5cm. If you use a 10cm diameter, the equivalent port length would need to be about 62cm, which besides being overkill is just plain ridiculous for a 16L box. Don't forget that you should also be subtracting the volume the port (as well as other interior objects) from the volume of the box.
** Or was that a 6.4cm diameter port? Which would need about a 25cm port in 16L for the same tuning in my example. Except again, I'm not accounting for the volume the port now takes up.......
Another opinion..
Played with this driver a bit... Works well in a 26-28 liter enclosure (gross volume) Tuned per Thiele's alignment. 2" dia. X 5" port tunes to 41 Hz. Or, 2.5" dia. X 8" port tunes to 40 Hz. No use tuning much lower as the volume of displacement of this driver will not support enough output below 40 Hz and if you do tune much lower your group delay is a real mess. Sounds nice, balanced, tight and smooth set up per above specs. All of the above assumes your drivers are close to spec. Have you measured them? Good luck!https://files.diyaudio.com/forums/images/smilies/biggrin.gif
Now i use in 16L a tube of 5cm diameter x 13,5cm lenght: tuning frequency sound be bear 60Hz.
For 42L box softwares give me a tube of 6cm diameter x 11cm lenght: now the tuning frequency should be 38Hz
42L or 28L 😕
Should try...
mine are in 21L with a 5cm dia x 7.5cm L port (low 40s). Excellent driver, but don't go too big with the box
- Suggestion for box volume
