Suggested bulb fof 15" lcd
I would go with a minimum of 250W and use a MH bulb with a 5500/6500K rating. a CRI of 90 is also something this bulb should have. you could go with a 400W too. you could use a double ended HQI or a single ended T-15. the double ended is a nice small bulb and will let you have a smaller enclosure. a T-15 requires your enclosure be at least 15" wide. you will have a smaller ballast with a 250W bulb too.
