Olá, tenho tido problemas com subwoofer Velodyne modelo DD . Anteriormente, eram problemas no módulo de potência. Recentemente, peguei dois subs com problemas comuns no stand by. Eles desligam por falta de sinal e não ligam quando o sinal voltava, algumas vezes também o display,, só voltando a funcionar quando desligados (desenergizados) Sendo que o problema volta a se repetir cada vez mais. Será que alguém pode me ajudar com isso? Obrigado!!!
This is an English language forum. You must post here in English. Below is the translation of your post,
Hello, I have been having problems with Velodyne subwoofer model DD . Previously it was power module problems. I recently got two subs with common stand by problems. They turn off for lack of signal and do not turn on when the signal came back, sometimes also the display,, only going back to work when turned off (de-energized) Being that the problem repeats itself more and more. Can anyone help me with this? Thanks!!!
