I have this EQ. My question is the output say's variable, 30-200Hz? So if I have a Subwoofer 18' and it says 38 to 175 hz will this EQ cut out any other frequency's below 100 hz if I set it at 100 hz or just act like a low pass filter and cut out only frequency's above 100 hz? thanks for any help.
It'll definitely act as a low-pass filter, set at the frequency you choose. Check the manual for the slope.
I don't know if the graphic eq will still apply to the subwoofer output or not - you'll need to refer to the manual on that one.
