Let's say that I want to build a integrated amplifier with 50K pots on the input. Let's also say that I wanted to control the volume of a subwoofer amp using the same 50K pots. Could I take the signal off of the wipers of the pots to the subwoofer amp in parallel with the grid of the input tube of the amplifier? I am using a Aragon A2D2 DAC and I believe that it can handle the load but I will soon be adding a turntable to my system so I guess I would need to make sure that the phono stage that I use would handle the load also. Does my question make sense?
