Subwoofer mounting question
I mounted mine outside, and didn't bother routing out the baffle to make it flush. It sure looks like it's made to make inside mounting easy. I suspect that's because it's intended as much for mobile application as home use, so it could be mounted from the inside of a vehcle trunk.
