post19 will go deeper and louder and have lower distortion if all 4drivers use their Sd against the air load.
Isobaric wastes half your Sd.
Is post19 a type of bandpass, or just a mess?
Post 19 is just a simple 6th order parallel tuned bandpass enclosure.
But with three chambers and isobaric loading the drivers to reduce enclosure size.
Thank you AndrewT, aznboi3644
Right now, I have 2 drivers isobaric incloser ( I can post Photo ) I am satisfied with deepness but not with loudness (because of 22 + 22 watt amp ) Amps already purchased and I want to use it.
@ AndrewT as I understood, I am loosing the loudness & half encloser size is the advantage.
AndrewT, If you have 4 drivers (8" 4 Ohms) & 4 amp (22 watt). How would you like to manage ? I wish to make more sound wave which come out via port as possible.
Thank you
Regards.
Thank you
Regards.
Subwoofer
Hi all,
for the ones interested i a really excellent sub, check TNT audio for the article in English as I can post this link : http://www.tnt-audio.com/clinica/trent.html which is only Italian.
You will be amazed.
Cheers
Andy
Hi all,
You will be amazed.
Cheers
Andy
