Subwoofer amp.(L + R audio to mono, summing??)
binsky3333
2010-09-14 2:30 am
Hey guys. My old amp from an old computer stereo system died. It contained a 28watt subwoofer. I plan on taking that out, and building my own amp. The subwoofer is mono(has a positive and negative terminal). I have been looking around at various amps, such as the TDA1554, which looks suitable for this application. The only problem with that amp and all the others, is that it requires a L and R audio input and outputs a L and R audio. My woofer only accepts mono. I was wondering if you guys could help me on how to go about this. I hear all this stuff about bridging and how you can combine two channels into one. How does this work? How can i combine my L and R audio into a mono channel? Also one last question. The purpose of a sub woofer is so exaggerate the lower frequencies. Typically 80-200hz i believe. In order to do that, would i just have to add a low pass filter to my amp?
Thanks guys, and hope someone can help me!
Also, i found this thread http://www.diyaudio.com/forums/car-audio/69590-mono-subwoofer.html
If you look in the second post, the guy is saying something about resistors, but i cant quite understand. Is he saying add the 2 positives, then add the resistor to that, then do the same for the negative?
