Subsonic problem
I don't know if humming is right word but best I can subscribe and lower than 80hz the bass I can here coming from the back of car and still up front tried lowering gain but no . When setting gain it has to be 80hz no lower or I can't set it.
It's a Nissan maxima sv with the Bose with navigation not using any of the Bose equipment it's still in car just not turned on so hu I have is in armrest ran seperate power wires and amps and everything. Not sure what you mean by main powered equipment you r talking about
I hear you. Tested ground from amp to battery , no engine noise or anything from other speakers. Checked resistance on subs they are fine used 9v on them that checked fine . It's as soon as I play a test tone they start making noise before I even touch the Gain and subsonic is at 10hz lp filter all the up everything flat 0 what not. With gain real low the bass sounds like it's coming from up front but I also totally here it coming from the trunk like not even part of the system. Idk bad subsonic dial, something with amp or Hu tried other Rca's no luck .
