Hi Åke, the Joachim Gerhard filter is specifically designed for ES9022/23. It needs the coils as they are essential parts for its exact functioning with ES9023.
I don't mind discussing the JG filter at all but its details should be discussed in its now threads. Integration with the Subbu V3 and the results (V3 sounds better/same/worse with the JG filter) can be discussed in either the Build... thread or the Modifying ... thread. We're here in the GB thread. I try to concentrate things so that I can keep track of information for technical support purposes (which we don't give, remember?).
Never tried the filter so I am not in the position to judge a thing. My built never got finished.
Links:
http://www.diyaudio.com/forums/digital-line-level/245233-build-thread-building-subbu-dac-v3-se.html
http://www.diyaudio.com/forums/digital-line-level/246003-modifying-subbu-v3-dac.html
Links:
Dear Builders/modders, I encourage you all to join the following threads for technical matters and pictures of your V3's.
Don't be shy and post pictures of your V3 and get comments of experienced builders. Regardless of you pride please post safely built V3's. One thread for building and one thread for modding the Subbu V3. Member Bcmbob undertook effort to make the first page of the Build thread a shining example of concentrating the info that was scattered all around.
This thread is for Group Buy issues only. Since the GB is over we can concentrate on building and encasing the DAC I think.
For you always Buzzforb even if I have to use the last one of my own stock. Thanks to you I have a DCB1 Mezmerize playing ! You know the virtues of group buys too well I guess. Please send me a PM.
Wow! - got my V3 parts package today. It has a 12/16/2013 date stamp, but as the French Prime Minister arrived in the U.S. today, I figure Korben just had him bring it with him on the plane, 😀
Thanks.😉
Thanks.😉
F. Hollande is the President actually. Prime Minister should be J.M. Ayrault if I'm not wrong... 😉...but as the French Prime Minister arrived in the U.S. today...
Hello All -
Limited quantities of PCBs (V3 / PSU) are left and will be first come first serve. Look at the first page and fill out the form. Then send you payment to the paypal address listed on the form.
Cheers
Subbu
Cheers
Subbu
Hello All -
Cheers
Subbu
Here is the link http://www.diyaudio.com/forums/grou...f-power-supply-pcb-group-buy.html#post3525366
Subbu, is the dac chip also available? Thanks. Kind regards.
Sorry. I just saw that it is. Thanks.
May I ask stuipid question regarding PCB.
I have already received two small packets from France with parts and there are no PCBs
As I understood it could be send separately from USA?
Am I right?
Am I right?
Subbu, just a quick question, will you send an invoice for this "second edition" GB, or should we just send you the fund after completing the form ?
Originally Posted by unixdeveloper View Post
Hello All -
Cheers
Subbu
Hi Subbu,
after filling out the request form, when can I expect a paypal invoice?
Best regards,
Fabian
Hello All -
I am not planning to send a formal invoice. Please calculate the totals based on the first post and send it to me by paypal.
Subbu
Subbu
- Group Buys
- "Subbu DAC V3 - ES9023/WM8804 SPDIF & Power Supply PCB" Group Buy
