hi
suppose if i build a small enclosure using Tang Band W2-2040S 2" RBM Micro Subwoofer 4 Ohm and cross this with a Dayton Audio BCE-1 22 x 14mm Bone Conducting Exciter, will there be any problems with the sub, even if it is separated by two diff sections?
since i am planning a portable stereo unit, i can use two of these exciters with a single sub, right?
can such an arrangement work?
75 to 2,000 Hz ... What people do with those things?
use it as a sub
