I am about to install 2 2X18" Renkous Heinz Qube sub woofers in a club B&C equipped...
I am some 25-30 meters away from the dance floor and the amplifiers, i have available 4 lines of 2X2.5 mm cables . I could locate the amplifiers one meter away from the subs but the Owner of the club will not do that ...
I have many good same amplifiers available though .... So the question is if it will work better to brake the connection behind the sub and operate 4 woofers distributed 1Woofer for one ch of amplifier . Each amplifier will operate at 8 Ohm load .
I expect less distortion when i am close to the peak less stress in the amplifiers and more total power
Is my estimation correct ?
