Sub integration
Not too sure what you mean when you say line level bass boost.
Do you mean bumping it up before amplification?
If this is the case then I am stuck as I am using an integrated amp. I could always try some GRF type cabs (either corner loaded or the 5 foot tall rectangular ones)
I love the mid & highs the Tannoys provide
Or I could just make cabs optimised for mid frequencies from the driver and add a whumping great sub😀
In my integrated amplifier I modded the feedback loop
of the power amplifier to boost low bass by up to to 8dB.
Very easy to do.
🙂/sreten.
The way you say it makes it sound really easy . . . . for an EE😉
I really would not be that confident about opening up my amp. First my wife will kill me if i break it, second although I have made some working gainclones I would be worried about making a crappy solder joint and blowing the thing up......it cost me a few pennies.
I have down loaded a basic version of WinISD and have entered the basic TS specs as posted previously. I cant work out the rest but I am sure as with all things electrical there are calculations to generate the missing info.
I have used what specs I have and I dont seem to be able to make a hige amont of difference whatever I do to the ports or the cabinet. Even a sealed cabinet has almost the same roll off.
What gives (is it just me?)
4fun said:
Hi!
Those modeling this speaker, isn't a passive filter included with a certain series resistance?
If so, have passive filters been altered? Lower resistance coils?
Q may have been lowered.
you are correct I didn't include the effects of series resistance
of the crossover coils, which raises the effective Qts of the driver.
See new Qts with series inductor here http://www.mhsoft.nl/spk_calc.asp
I have used what specs I have and I dont seem to be able to make a huge amont of difference whatever I do to the ports or the cabinet. Even a sealed cabinet has almost the same roll off.
Nope, you are not doing anything basically wrong. As stated you
need some form of bass boost. Experimenting with putting a BSC
type circuit between the CD player and its input is a possibility.
With 6dB to 10dB maximum boost depending on room gain
placement etc bass down to 30Hz is certainly possible, and
with two 15"s at reproduction levels you can easily hear.
🙂/sreten.
