Need to build a sub for at the office. Room is about 400-500 sq. ft. and the unit will but sitting under my desk. Speakers are Mirage Omni-150 running off a Denon receiver.
All music, but I prefer my subs tuned lower. I like the sub on my Klipsch Pro Ultra 5.1. On my home theater I have a Paradigm Monitor SE Sub which is the only sealed sub I have ever liked but its still missing the low end punch I like.
So I am undecided between a ported or 4th order bandpass enclosure.
Pictures of my setup. Sub position isn't 100% fixed, I can move it around under the desk some.
Read the creative sound trio 12 was highly reccomended. Couldn't find it on the site but see a combo 10" sub with amp for under $400.
Creative Sound - Product Details
Is there a better bang for buck than this? Or for my application? The 24.5Hz vented tuning example in the spec sheet sounds pretty close to what I want.
It could use some kind of bass boost or EQ, looks like the PE only has the basics main level and crossover. An EQ will give it deeper punch.
I wouldnt get the kit because it comes with a bash. They made a lot better plates up to a point.
Would the kit with the Yung be better? Creative Sound - Product Details
I have first hand experience with BASH poor quality (Klipsh amps) but don't want to spend a ton of money on this either.
What plate amp would be better? I was looking at Class-D boards on ebay but then would need a power supply and make an enclosure.
Part of me thinks I need to go up to a 12" woofer, not sure why. Don't really want a 20"x20"x20" box under my desk to kick with my foot. Most of the time this will at very moderate listening levels as to not annoy others in the office, but I do have times after hours and on weekends that I can crank it while I work.
Other than sound you'd hardly notice a couple sealed 8's stowing away under that desk. Id try one at each end.
Whats the most you would like to spend to arrive at a finished sub?
Was really only wanting a single sub.
I am leaning towards the Creative Sound - Product Details
If the curve for the larger enclosure can be believed it looks like that would go low enough for my preference and would mate well with the -3db 55Hz of my Mirage speakers.
You don't have to build a pair… i was pointing out that i had.
That kit looks fine. When i looked at all the CSS drivers i decided the 10s had the best HF response and went low snuff. I am also partial to push-push pairs in a box. The active vibration cancelation of the push-push pair significantly reduces the load on the box (ours are built with 15mm BB and i have to turn them up 10dB above loud to get the box move -- and that could well be caused by harmonics as the amp clips)
dave
dave
I did like the Klipsh which is side firing push-push with 8's.
This is being used in an office though so very rarely will be played at reference levels.
Someone else pointed me to Rythmik Audio 12" Servo subwoofer " GR 12" Custom Installation subwoofer
Which I like the idea of direct servo and didn't realize they had kits that cheap... but after exchange and shipping that's $730 CAD 🙁
This got me thinking and I found Equalizer APO for windows and downloaded it.
It's helped a bit at home, still need to play with it. Really need to get a mic.
But at the office is where its really helped. Boosted 20Hz by 6db, 33Hz by 10db, and 63Hz by 8db with -15.7db on the preamp. These speakers amaze me.
Looking at the response graph of the sub I used to have here, perfectly flat from 55-65Hz and dipped at 80, peaked at 48Hz, -3db @ 40Hz -10db @30Hz . Bandpass with a 8" driver. I liked this sub other than it didn't go low enough. I might actually see if I can find a plate amp I can replace the one it had with. Hopefully it didn't have too much DSP going on that I wont be able to replicate.
Still looking at the SDX12B http://www.creativesound.ca/pdf/Duet12XBL.pdf. My only fear is the high end roll off would be too much. Been playing with Equalizer APO for windows, maybe I can compensate for any lacking in the 60Hz-80Hz range with EQ.
Ok, gonna go with the SDX12 from CSS. Been designing an enclosure, tell me what you think. 76.2 L net volume not including the driver/amp. The CSS graph PDF stated 73 L, I assume there figure includes the driver displacement.
Also have a detail drawing here
https://bun-bun.ca/cirrus/index.php/s/PRZ4VfBcCmG5rAU
I'd suggest that whatever plate amp you settle on that you provide a separate sealed enclosure for it. Politely put, I'm of the opinion that sharing the enclosure with a sub woofer driver is not the best plan for long term durability, and even when "sealed" every plate amp I've seen/used had a flimsy plastic cover. Better yet might be something in a completely separate cabinet, like a Behringer NU1000 - even with currency exchange, etc, landed cost should be cheaper than the BASH. As an authorized Parts Express reseller I'm sure Bob could probably order one for you if you like -and there may be direct Canadian suppliers.
I could fab an aluminum cover for the inside of the box to cover the amp.
https://www.amazon.ca/Behringer-NU1000-Ultra-Lightweight-High-Density-1000-Watt/dp/B005EHIN12
That and the SDX12 separately would be ~$610. $110 more than the kit with the bash amp.
Brace the magnet against the rest of the box. As it is the baffle is taking the entire load.
dave
dave
Like this?
I thought the driver shouldn't be touching anything other than the baffle to eliminate chance of internal buzzing/rattling.
Should the magnet be under pretension with the bracing?
It is a 1.5" baffle.
That would help, but you are only bracing it to the brace, it should be solid all the way to the back of the box (where the plate amp gets in the way).
Here is the inside of our twin SDX10 box to give an idea. It does have the significant advantage of having active reactive force cancelation.
The brace should be firmly against the magnet but not stress it. We have had no problems with it causing any noise (many, many builds)
dave
dave
Picture showed up later.
How about this?
The vertical brace is one peice all the way to the back. The horizontal are split between the vertical. I took out the horizontal and corner ones for clarity on the second pic.
In case its not clear I have the horizontal bracing wrapped around the magnet the magnet the same as the verticle, which also connect to the back.
I did this edit quick and rough. Will have to fine tune it and make it look nicer.
How about this?
Better. A direct path to the back of the box would be better, but that plat amp… last time we did a sub with a plate amp, we put it into an add-on box on the back of the real woofer box.
dave
dave
- Subwoofers
- Sub for Office
