Yup , and my spooky amp uses quantum entanglement for it's input
stages. 😛😛
Edit - but I really know the 4 LEDs have quantum wells.
OS
stages. 😛😛
OS
Coincidentally, Class Digital 6 is entering new frontiers bringing new unexpected sound purity. Three high quality modules are set side by side: first one is amplifying the music, the second one the shared power supply noise, a third Digital amplifier receives both signals at 180* and perfectly cancel inside the difference. Advanced clocking scheme distribute a 3D master clock signal. 100% designed in Canada. To bring even more excitement we offer today a bridged version for 3 way active crossovers. Diy kits will be available with balanced preamps: total 36 class D amplifiers can produce a clean signal of 600000 Watts and instantaneous 6000kW required to realistically reproduce live performances. We offer soon the technology for 7.1 sounds coming next year.
Be careful not to mention the added dimension.
if memory serves me the combined use of feed back and feed forward together in the same amp is not new at all check out Black's work and the Quad 405 uses both. Best regards Moray James.
Joined 2009
I have entered into an exclusive contract with Bear to distribute his new product. He has authorized me to release the first photograph of it.
Through good fortune we have also established a reliable supply of all the necessary materials and we are ready to enter production in a few weeks.
If you'd like to pre-order your kit please contact me directly. The mono version will be priced around $100k, the stereo version at $200k but we can offer different colours for the L and R channels for an extra $20k. Multi-channel versions may be available at a later date under the 'Ribbon' trademark.
moray,
I would hope that Bear's new design is not a copy from Quad and is truly something unique.
Rumor is this thread will soon match Blowtorch for number of posts! Wow!
The comment from the team's lead engineer tells all: "...I have no idea how the h**l we are ever going to measure this thing, the only way I can tell it apart from a wire is that it has a different looking noise floor!..."
_-_-bear
Perhaps I can measure the distortion with "DiAna", which has a measurement floor of ca. -170dB. 😀
That must be an early prototype - it's nowhere near anything like linear 😕
Jan
Who need linear, when we can have exponential ?it's nowhere near anything like linear
Moray, this is somewhat different.
This system uses a new type of topology that is not a two terminal, or 4 terminal device (when analyzed mathematically), this is a 6 terminal device. One may chose to think of it in terms of "6dof" or six degrees of freedom, as a mechanical equivalent.
The traditional feedback method is more or less a 1dof method.
Here it is more than merely looping back, or looping ahead. The distortion cancelling mechanism depends on being so much faster than the propagation of the amplified signal, that in effect it is more or "waiting for the train to pull into the station". This is what accounts for the stunning performance!
_-_-
Fisher Amp a.k.a. Fish for the Masses!
This kit is the stunning "No F/B - No Gain Amplifier" designed by Prof. Fisher.
Please pay attention, circuit is patent pending!
For commercial purposes you should slightly modify the circuit design. For example, consider a color change of the wire coating. The dark yellow color seems have a lowest molecular density permitting the fastest transit time to atoms and related distortionless signals, temporal coherence and zero phase rotation. The best unity gain amplifier i've ever seen!
I'm surprised no anti-matter seemed to have been involved.....or perhaps you are holding it back for now?
Look, this is serious stuff.
The basic principal is based on the sub nanosecond propagation time in the "error correction" portion acting upon the lethargic turtle-like already low distortion topology of the main amplification path.
The only reason that we at BEAR Labs have been able to implement the design in hardware is that we have access or entre to the nearby nano-tech center that has a specialized foundry. Working with their staff, and some select post-grads we solved the timing problems by stacking and interspersing the ultra-highspeed GaAs circuitry with the standard silicon path. Solving the problems of creating circuits that have unusual height was quite a challenge. Path lengths were critical and sometimes in the nanometer scale. These being in height. Remember now that the fast path has to be so fast that it is in effect "waiting for the train to arrive", and then the Correlated Relational Angular Phase control circuit has to be very precisely laser trimmed.
So the result of this is what has been called "Super Height Integrated Technology".
THAT is what makes it possible!
Read it and weep.
_-_-
Read it and weep.
_-_-
Oh , the Nano lab off of I-90 ? Every time I rode by I thought
of melted trees and people emanating from this "ground zero".
Like in the "G.I. joe movies , Cobra's base is off of I-90 , underground. 😀
They make the "nano bombs" there.
....or "nanogoo" by mistake" -
OS
OS
That transfer function has a definite curve to it. Like any good marketer, he's probably had an upgrade path in mind right from the initial clippings- I mean, design...
-- Jim
Joined 2006
this thread reminds me of the LIRPA turntable/phono many years back....😀
I kept the copy of the Audio Magazine for years and thought it was real😛
- Stunning Amplifier Development!! Feedforwardback & Feedbackforward
