stuffing the folded fe167 cabinet
Has anyone built the ML folded for FFE167 using the following plan ?
http://geocities.com/rbrines1/Pages/Proposals.html#Fostex FE164
Let me know what is the damping and stuffing material you used. From where I live, I only find the pillow fills (polifills) and packing foam. I may find some fiber glass if I am lucky ! According to the plan above, it only requires polifill and nothing else. Please give me some advices. I read many threads about this topic but could not see any discussion about damping this type of cabinet . Thank you
It's just Martin King's seminal Project 2 ML TQWT folded in half. I've build 3 pairs of the unfolded version. Stuff the entire rear part of the line (the narrow bit), and if you can, line the back wall, and one side, behind the driver, with damping material. That should work fine -it's what I used. Dacron hollow-fibre pillow stuffing is ideal. Forget the fiberglass -nasty suff. Bad for the health; it irritates the skin when handling (if you don't wear gloves), and isn't much better than MDF dust for your lungs either.
Just my humble opinion, but Acousta-Stuf fiber from Parts Express (P.N. 260-317 (1 Lb bag) & 260-330 (5 Lb bag)) is about the best material you will find for TL enclosures.
It is made of Nylon polyamide fiber, with a multi-directional crimp that gives each strand a greater amount of surface area for heat dissapation than wool or Dacron fibers.
Larry
