Time to clear out some of my parts, and other stuff.
Boards/etc.
Borbley DC100 raw boards, $5.00 pr
Superphon SA120 amp raw boards, $5.00 pr
Superphone SA120 bds one stuffed, one with all parts. $10.00 ea
Superphone S400 amp raw bd. $5.00 pr
Superphone DM200 amp raw bd. $5.00 pr
B&K Sonata driver bd stuffed, and pr output bds, $15.00 set
NYAL Moscode Minute Tube Pre-amp bd and P/S xfrms, one channel works, other needs Fet (I have Fet). $25.00
DB Systems MC Pre-preamp, works. $25.00
TT speed controller for 12v ac motor. $20.00
Parts
Custom wound OPT for SV-811, 5K/16ohm, 40W, 160ma $30.00
Custome wound OTP w/nickel-cobalt lams 2.5k/8ohm, 8W $150.00 pr
NTE 2383 Pwr Mosfet 100v, 10a $4.5 ea (have 50)
NTE 2382 Pwr Mosfet 100v, 10a $2.50 ea (have 50)
Daven NOS 18 pos switch, nickel contacts. $10.00 ea (have 4)
Need to replace Blue Point MC that got damaged , so have pity on me, no vinyl for a while. Got a good MC-trades?
Send email for pictures, multi item deals, or make offers.
More parts to come, mostly tube related.
Boards/etc.
Parts
I've had several emails on the Nickel/Cobalt OPTs, so eaiser to answer here.
They are NEW, never used, tested. Last pair of four I had custom made for me. Designed for parafeed 2A3 or 300b. I'm currently using one pair in a parafeed 2A3. The $150.00 is firm, as I have more than that into them.
My home PC hard drive crashed and I lost some prior emails, so the folks that wanted the Pulley for the AR-XA (I found it) and the AC motor controller, please email me back. I will hold those items for a few weeks.
Other TT items
AR spring set w/ lite-Med and Hvy conical spring (3 ea. for a total of 9) $10.00 set
AR-XA arm $15.00
AR "S" arm wand $5.00
AR Aluminum/foam samwitch arm board $5.00
Aluminum 3-point cartridge coupler $10.00
Premier HL-29 LC-OFC Copper Litz leads, NIB $15.00
Oak 7" arm tube $8.00
Blk head shell $4.00
Maxon DC Motor 110191 new never used $88.00
Matching Brass Pulley from 2007 buy never used $25.00
-or looking for the PC raw board to finish the project.
Superphon Revelation G preamp board, stuffed, working $25.00
As before email me for pictures, multi item deals.
Other TT items
AR-XA arm $15.00
More items
Mortensen DC300b tube driver bds for fet output stage. Stuffed w/ hi qual pts, w/ tubes. Working. $40.00 set
Super Reg bds, one stuffed, w/pts. $35.00 set
EV SP12b spk. $35.00 pr
Ohmite Reostats, 25W (use for adj cathode load in SE amps). $3.00 each, deals on multi item lot.
13 50 ohm
4 350 ohm
6 400 ohm
3 2.5K ohm
1 10K ohm
1 20K ohm
email for info, pictures, offers. Stay tuned-more to come.
13 50 ohm
4 350 ohm
6 400 ohm
3 2.5K ohm
1 10K ohm
1 20K ohm
Speaker for sale
Periscope spks w/ RS 4" (Fostex FE-103a). $50.00 pr
MCM 55-1200 5" mid-bass driver. $10.00 ea (4)
MCM 55-525 1" poly dome tweeter. $10.00 ea (2)
-see MCM web site for complete specs.
Audax DW50m Tweeter w/ wedge mounts. 4 ohm 94 db. $20.00 ea w/ mount, or $15.00 w/out. (2)
Blaupunkt P652c 2 way coaxe. 6.5" 4 ohm 91 db 65 to 20KHz, 40W $25.00 pr
EV FS-1950 spider for recone. $5.00
EV VC-9200 voice coil for 15 inch spk recone. $5.00
EV SR-15 basket gaskets for 15 inch, 1 set. $2.00
EV-DC7172 dust caps. 2.75" for 12 or 15 inch driver. (10) $1.00 ea or 10 for $8.00
Waldom AA-78 spk cement. One quart bottle, new unopened. $10.00
Waldom AA-76 spk cement. One quart bottle, new unopened $10.00
send email for pictures, info, offers.
