Hi All,
I have a JBL GT4-10 Sub, i'm looking in to making my own box for it, to go in the boot of the car.
i've been round and got various programs that work out box dimensions. but i've not a clue...the dimensions it gives me for the spec of the sub are strange, ie. the front face of the box, where the sub would be mounted, i have less than 20mm either side...
my maths skills are practically non-existant so i can't work it out my self, well won't because i'll mess it up =\
so if anybody knows what they're doing when working out dimensions....i'd be very grateful
Specifications
RMS Power Handling :250W
Peak Power :1000W
Frequency Response :28Hz - 500Hz
Sensitivity :90dB
Impedance :4 Ohms
Voice-Coil Diameter :50mm
Cut-Out Diameter :232mm
Mounting Depth :150mm
Overall Diameter :258mm
Vas :36.10L
Qts :0.42
Fs :29.6Hz
Qes :0.45
Qms :6.45
Sealed Enclosure (vol) :21L
Sealed Enclosure (vol) :50L
^^ eh? sealed enclosure two different numbers for the same thing =\
any help on this would be fantastic...
Specifications
Peak Power :1000W
Sensitivity :90dB
Impedance :4 Ohms
Vas :36.10L
Qts :0.42
Fs :29.6Hz
Qes :0.45
Qms :6.45
