I am looking for information on the effectiveness of various approaches to minimising structure-borne and air-borne vibration in turntables. So far, I have turned up little of substance on the web and was hoping one or two here may have a few useful pointers. Many thanks.
I suspect nobody has actually measured it. In theory, a suspended sub-chassis turntable behaves as a high-pass filter above its resonant frequency (usually tuned to 5Hz). Turntables like the AR XB1, Thorens TD150, Linn LP12 etc used this technique. It's awkward cueing on such a turntable.
The currently fashionable technique is to have a platter that weighs so much that sheer inertia prevents structure-borne vibration. Platters upwards of 20kg are not uncommon. They're also heavy on the wallet.
Doing anything about air-borne vibration would require enclosing the turntable in a sound-proof box. Another room, perhaps?
Hi EC8010,
There are some platter mats that "bond" with the LP to make it part of the overall rotating mass. I still have a "platter matter" that does that. You have to peel it off the record when you are done. I use mine on a Thorens.
-Chris
-Chris
works with non suspension tt's very well:
laminated plate (1/8 steel glued to 1/2" mdf in the centre) to have a "dead" base, float the base on an innertube - app. 12 - 16" diameter.
Works very well on my transcriptors hydraulic.
Also - found that having the cover down on the tt during playback greatly increases resonance from the ls. Easy to test. So no covers on my TT's.
Thanks for the responses.
It is not difficult to determine by a variety of approaches. For example, the simplest is simply to play something through the speakers while a record is spinning in a silent groove and to listen to the phono output.
> such a turntable.
I have had no problem cueing on such turntables but banging about on sprung floors does cause problems. I do have a unipivot with a badly designed cueing mechanism which is awkward to cue.
Mass in itself has no direct effect on vibration isolation (but can in combination with stiffness, damping and other properties) although, of course, it can help even out an uneven driving motor.
That would be the simplest approach but it is rarely if ever done. Why not? Is air borne vibration so small as to be irrelevant?
Somewhat impractical except for experiments.
If the platter is vibrating then is bonding to it wise? If the record is vibrating from air borne sound (it has a large area) and/or from structure borne sound from the stylus then is a strong bond what is required?.
What is the ls?
Thanks again for the responses but I was really after some numbers to quantify the phenomena mentioned above.
> such a turntable.
What is the ls?
