strong portable sound system
I would like to make a system with which I will be satisfied. It will be used in smaller spaces up to 150-200 peoples, mostly electronic music.
And must be small and easily portable.
I had the opportunity to hear nexo ps8 witch are 8" with ls 400 bass. they are really powerfull.
So, what dou you suggest?
You are much too vague - if you want more people to help, tell us details of size limit of the box, desired operating SPL and max SPL at what distance away, desired bass extension (-3dB point), and cost limit.
It sounds like you are looking for a PA system, in which case this may not be the best forum.
Nexo PS8 is a 125 dB at 1m capable 8 inch PA system with a CD horn tweeter. Is that what you are looking for but with a full range driver? Can't be done. Try a pro audio coaxial in a bass reflex or sealed box.
This driver at 96dB at 1 watt 1 meter should be able to get you close: http://www.parts-express.com/bc-8fcx51-8-professional-coaxial-speaker-100-x-100-8-ohm--294-5766 and be pretty compact since no separate horn is needed.
Or this one: http://www.parts-express.com/bc-8cxn51-8-professional-neodymium-coaxial-speaker-100-x-100-8-ohm--294-5764
Or if you are on a budget, this one plus a CD of your choice: http://www.parts-express.com/eminence-beta-8cx-8-coaxial-driver--290-500
From what I can gather you are looking for a 3 way with a 15 inch woofer and an 8 to 10 inch top in one unit? That is not a compact package anymore. You may want to check out a very nice 2 way by Jeff Bagby called the Tempest. It is only 12 in woofer but is 97dB efficient and reaches 40Hz.
Fusion-12 Tempest - Waveguide Speaker Kits DIY Sound Group
A lot smaller than a 15 in woofer box.
If you still want 15 in look at this variant:
http://www.diysoundgroup.com/waveguide-speaker-kits/fusion15-kit.html
