Strange (?) voltage spike during capacitance multiplier start up
Hi! I have built a MOSFet cap multiplier to filter valve amp B+. Here's the schematic:
Real life DC behaviour on the bench matches the simulation closely.
I have a meter on the load resistor and a meter on the output of the PSU powering it. It is an old unit with an indirectly heated full wave rectifier, so comes up slowly.
The cap multiplier has the typical slow startup from the time it takes for C1 to charge. At the point where that is nearly finished and Vin starts to drop, there is a click sound to be heard from the cap multiplier and Vin jumps up to 1kV for a moment. Unloaded Vout of the psu is 510V, under load 484.
Do any of you have an idea where that spike is coming from and how to suppress it?
Thanks for any useful input.
It's very weird. Weird behaviour is often related to oscillations, but there is no overall feedback and you do use gate stoppers.
The input voltage jumps up to 1 kV and then goes back to normal... Have you got a schematic of the supply that supplies the input voltage and if so, could you post it? What load is there on the output? Does it behave better with maximum than with minimum load?
High Marcel, thanks for getting back. The gate stoppers are dry carbon comps, with their bodies soldered as close as physically possible to the bodies of the transistors. The values of input and output capacitor are not random but were chosen to make sure phase is in order.
I would have to open up the supply to trace the circuit. Relevant might be that it is a CLC supply, meaning there is an inductance that possibly discharges the moment gate threshold of the pass FET is reached.
Load on the output is an 8k resistor. I'll have a look what happens with different loads and maybe try a damping resistor at the input of the multiplier.
The inductor may be causing the voltage spike, due to a bad connection or arcing.
Try substituting a high power resistor (of the same DC value as the inductor) for the inductor and see if the problem is gone.
I wondered about that in post #5. I'll take out the inductor and replace it with a resistor and try again. As the amplifier wthis was supposed to go in has a lot of L in it's supply, is there a proper way to deal with that kick back? Damping diodes across the inductor?
Thanks for the input.
Inductor + switching device = kickback. Hence the need for the free-wheel diode across the inductor. Not sure what the inductor does, other than risk over-voltaging the drain of the FET and sending it into avalanche-breakdown, and limiting the bandwidth of the regulator, no need for it in a linear regulator circuit like this.
