In this case it´s not gated, it is lineary controlled - page 1 from the datasheet I mentioned:
The overlimit inhibitor is just the zener, which makes sure it doesn´t compress the signal too much.
I am about to buld this preamp, so I am first trying to know how to troubleshoot it - what to measure, and also to know how it works.
The CA3080 and CA3080A types have differential input and a
single-ended, push-pull, class A output. In addition, these types
have an amplifier bias input which may be used either for gating
or for linear gain control.
" ...The overlimit inhibitor is just the zener, which makes sure it doesn´t compress the signal too much. I am about to buld this preamp, so I am first trying to know how to troubleshoot it - what to measure, and also to know how it works. ..."
That Schmidt Trigger (U8A) is definately serving a "digital" function, shutting down the CA3080 in a "snap action", latching methodology. ( http://en.wikipedia.org/wiki/Schmidt_trigger )
I might have chosen a different pre-amp design ... but ... to each his own purpose. Go for it!
Does this look familiar? ... http://en.wikipedia.org/wiki/Image:Opampschmitt_realistic_xcircuit.svg
But it is not a schmitt trigger..., If you have some simulation program then use it and you will see the output of the amp moves slowly, and the output to the CA3080 has of course 10-2*V_forvard of the two diodes, and the current changes slowly from 1uA to 2.1mA with input form -10mV to -12V.
The graphs before were incorrect, because I didn´t simulate it with the load connected- two diodes in series.
