Hi, i build my first lm3886 amplifier. Everything is ok but..i have a strange problem.
The wire from potensiometer's out that goes to the chip board line-in is very sensitive to noise(for both channels). When i touch them( or moving my hand above them) the speakers make noise.
I had them twisted at first, but a had a noise problem. Then a removed the twisting and the problem gone for a while but today it started again..
My case is wooden and only the top surface is aluminium. When i remove the aluminium the noise is very little, but a can hear it late at night. when i mount the top aluminium surface the noise gets a little more audible, even if no wire is touching it.. I noticed that if i connect pot's in with pot's out (as like no pot is there) the noise almost dessapears...its very hard to hear it even if you are too close to the speakers(2-3cm).
Any recommendations?
these are the wires that cause the problem..its a little messy i will fix it soon.
http://img706.imageshack.us/img706/6024/wires1.jpg
this is the aluminium cover..
http://img571.imageshack.us/img571/9646/topvu.jpg
The input to the chip board should be from the middle leg of the pot, you have it miswired![]()
Are you sure?? I have the line-in in the middle, not the chipe signal-input. is this problem?
The star ground point is on the wooden case. And no, i haven't connected the aluminium cover to the start ground...Is this nessesary?
I've had chipamps in open air without case and never experienced noise problems.
The pot is always wired with signal to pin 1, amp's input to pin 2, and ground to pin 3. This way the input starts off short-circuit (no signal) and goes to full output (full signal) as the pot rotates clockwise. The way you've done it, the amp input starts off by seeing an open resistance and the line-in starts by seeing a short-circuit.
With the shaft facing you, the left most is pin 1 and right most is pin 3. Pin 2 is the wiper.
hmmm i changed the wires as you told me and there is no sensitivity anymore!oh yeah baby.
But the sensitivity is gone for sure! thnx mate
Chip volume
Also, wire lengths should be short and neat, and if a ground plane board is used, the wires (bundled) should be tightly run along the surface of the board. In some cases it should not touch the board, but it is easy to find the correct way (less noise).
You could use fixed resistors in the NFB network for volume too.
- Chip Amps
- Strange GC noise problem
