STM32 Blue Pill
STM32 Blue Pill
STM32F103CBT6, STM32F103C8T6 Blue Pill version J.1 (Right version PCB, non China's version, PCB with LDO AMS1117-3.3).
PCAD2006, PDF and gerber files.
See attachments.
PCB dimension 53.34 x 22.86 mm, distance between XT1 pins and XT2 pins 15.24 mm, min line width 0.20 mm, min clearance 0.20 mm, other lines width 0.50 mm, 0.40 mm, 0.30 mm, 0.25 mm, VIA D=1.0 x d=0.5 mm.
PCB's components type are SMD.
Resistors, non electrolytic capacitors and LEDs are 0805 dimension type.
Electrolytic capacitors are SMD C dimension type.
Original PCB STM32 Blue Pill has SMD components with 0603 dimension type.
STM32 Blue Pill
STM32F103CBT6, STM32F103C8T6 Blue Pill version J.2 (Right version PCB, non China's version, PCB with LDO AMS1117-3.3).
See attachments.
PCB dimension 58.42 x 22.86 mm, distance between XT1 pins and XT2 pins 15.24 mm, min line width 0.20 mm, min clearance 0.20 mm, other lines width 0.50 mm, 0.40 mm, 0.30 mm, 0.25 mm, VIA D=1.0 x d=0.5 mm.
PCB version J.2 is fully compatible with PCB version J.1 .
Some new components added to circuit and PCB.
Resistors, non electrolytic capacitors, LEDs and inductor are 0805 dimension type.
  • Thank You
Reactions: lalaina
