Hi
found on my fathers garge a vintage sanyo R5 Tuner+Amp.
one audio channel does not work so i guess the chip is dead.
the chip it uses is STK 461.
its not easy to find this chip as its old, ive tried Ebay and the only one that ships world wide costs 60$+
any idea where to find this part with better price (that ships worldwide)?
perhaps i can use a different chip that might be available localy?
does it even worth fixing?!
thanks
thanks
Don't guess the chip is dead. Find out what's wrong with it instead of throwing time and money at the unit.
hi all
i have replaced loads of stk's since the suv2 and such amps went this way to simplify amplifiers, reworked a classic akai am-u1 and the kid blew the module by connecting 2 pairs of drivers and a mixed input into the aux or whatever, does anyone know of a pin compatible replacement or any 2nd hand working stock?
Pity as it was hid dads and is as new.
regards
44ct357 cape town sa.
regards
STK461 is a lower power version of an STK463 which is a lower power version of an STK465.
The higher the number, the higher the power and voltage. They are pin for pin replacements.
stk461 | eBay
stk461 | eBay
Sometimes, if voltage/current/power permits, I use an monolithic IC from TDA line adapted to PCB with as short as possible connections (probably the bias in the STK461 differs from the necessary input bias to TDA and will need adjustment).
