Stereo to mono: is this schematic safe?
You even don't need the resistors, since nearly all op-amps have them protecting the output. I usually go with 4.7-10K for line level.
The 100 ohms (typical) output resistors on opamps are to prevent oscillation into
a capacitive load, opamps are safe into a short-circuit by design (otherwise they'd be blowing up left, right and centre!!)
The vast majority of opamps can't drive 100 ohm loads without distorting, 2k--5k resistors are a good compromise (higher gives more noise and HF fall off, lower stresses the driving circuit more)
