I have these stereo amplifiers - Adafruit 20W and Sure Electronics 15W
If I connect this passive stereo to mono bridge at its output, will it technically be a good solution? Will the amps work correctly?
I have searched and searched for modules which can take in stereo inputs and output mono, but there isn't just any available.
Anyway, is there any other technique to help with this. Or any other amp which can support simple twisting of wires to get it play only mono from a stereo.
PS - Got a 15W driver with 4 ohm. Need to work with 4 ohm.
I think that is more oriented to the input side.
Maybe if you connect it at output nothing explodes, but it's not designed for that use.
The general rule is that Class D amplifiers are generally more complicated to bridge than simply joining two cables together.
This is interesting. So if the source, like from the phone jack, itself is connected with that passive bridge, then I just need to hook a mono to mono amp at one of its output side and leave the other output of the bridge as is, and that would get us to a solution?
