Stereo Subwoofer
After months of deliberating about my under-bed subwoofer I have decided to build it out of the components I already possess. 60w + 60w amplifier + 2 x 165mm drivers. The cabinet dimensions are 600(W) x 200(H) x 200(D).
It makes sense to power each driver separately. So here's the question . . .
If I use a full size panel as a brace I will effectively have 2: 300x200x200 cabinets. It is easy to calculate port size and tuning frequencies. However, without the brace I will have two drivers using the same airspace and sharing a single port. Will this configuration produce better results?
