I'm looking for a chip amp that meets the following:
powered from a 24 volt (single) supply.
2 Channel
Ability to drive 4 Ohm loads.
low part count to keep costs down
fixed gain preferable (less parts)
Single ended (no BTL)
I'm thinking like a TDA1517, but with higher voltage supply that means higher power output.
Thanks!
2 Channel
Thanks!
noo its to do something with keep ing output capacitors charged or preventng dc from causing loud pops when powerd on , nothing for efficency jst safty and stabilty
not for the above ....just to bypass the stored charge in the capacitor to supply rains when power is disrupted.In other words to safeguard the output transistors inside the chip.
- Chip Amps
- Stereo power amp, 24 volt supply
