Stereo Pententometer Questions
Hello everyone,
I built the 16 watt stereo tube amp kit 16LS from S5 electronics and I'm having problems with the volume control. It needs to be replaced but I don't want to use the same one. It's shorting out and causing the amp to go full volume on its own. I was wondering if anyone could recommend a good one for this amp. I don't think the original can handle the current or voltage that goes through it. That's my guess. If you could give me a part number that would be great. One day I want to build a PTP amp but for now this will have to do. Thanks in advance.
Aaron
Try this 100k SMD resistor stepped attenuator from eBay seller tube_buyer. I've used a few of these with great results:
SMT Resistor Step Attenuator 100K Volume Control - eBay (item 330453566190 end time Aug-20-10 03:50:46 PDT)
I also like the Alps 100k volume pot from Radio Shack (PN 271-1732):
100K Dual-Ganged Stereo Volume Control - RadioShack.com
Lastly, if you can go with 50k and different pin configuration, try the Panasonic EVJ volume pot from Digi-Key (P/N P2H2503-ND):
Digi-Key - P2H2503-ND (Manufacturer - EVJ-Y10F03D54)
I actually prefer the Panasonic EVJ volume pot the most. It works reliably, tracks well and doesn't color the sound. The pin configuration is different than most standard volume pots.
