Stepped-Attenuators = Thin Lower-Mids?
OK, since this thread seems to have run its course, perhaps it'd be a good idea to summarize my findings (here and elswhere, in the course of my 'research') for the benefit of those who're, like me, new to the in-depth subject of volume-control. (Understandably, technically-oriented, and long-standing, fans of passive 'pre-amps' are the undisputed experts on this topic. And my own comments should, ideally, be viewed in the context of the recent discoveries of a long-standing audiophile who may be reasonably learned in most areas of high-end audio, but relatively new to this one - a novice in this particular field).
Stepped-attenuators are, in my view the standard-bearers in the field of volume-control. For those of us seeking the very best in transparency, and overall sound-quality, all other means of V-C (volume-control) must be measured against (the best of) this standard. However, there's a caveat in the fact that some seem to believe that atts tend to thin-out the sound, as compared to other means of V-C, which do not display this trait. The results of my investigation, in this regard, are inconclusive. The fact is that most of those, who aired such a concern, were using DACT attenuators, though other brands were also implicated. On the basis of my findings, I'd be inclined to believe that there is a ligitimate concern, regarding a thinner midrange conveyed by DACT atts. Fuller mids seem to be a feature of both the Goldpoint, and TKD atts. As to whether these eradicate the problem completely, I'm not sure. Nevertheless, according to a comprehensive study done by John Curl, designer of the Blow-Torch pre-amp, the very best stepped-attenuator of all is, in his view, the top TKD. (A reference to his findings is linked elsewhere in this thread).
Potentiometers (carbon-based, or plastic) generally speaking are less transparent than atts. However, the very expensive, $1k, ALPS RK50 is THE EXCEPTION, with reputed transparency comparable to the best atts (but at much higher cost). At a lower level, the best TKD pot is alleged to be close (but not quite there) to the quality of the better atts. Citing a few of the popular examples, the consensus seems to be that the sound-quality of pots, in ascending order of ranking, would be; Blue-ALPS, PEC, and the afore-mentioned TKD (Based on what I've gleaned, I'd guess that the Black-ALPS would be either equal to the PEC, or somewhre between PEC and TKD).
Transformer-based volume-controls (TVC and AVC) are, generally, much more expensive than atts. The sound-quality is usually comparable, with the best of these alleged to be slightly better than stepped-attenuators - a claim hotly debated by att-advocates.
Light-Dependent Resistors (LDR) volume-control, by all consensus, seems to be the very best means of V-C, with singular regard to sound-quality. Many, who had previously used atts, now attest to slightly more transparency and resolution of low-level detail, with their current use of LDR V-Cs. The same applies to those who'd previously used TVCs. There are several LDR passive 'pre-amps' avalable in the form of the likes of LightSpeed, WarpSpeed, Eva, etc. However, though perhaps all can be used in the context of a replacement volume-control for an active pre, perhaps the most attractive, in terms of physical-fit and cost (comparable to an att in both regards, effectively) is the OptiVol LDR volume-control by Ska. With regard to its sound-quality (in the context of passive and active applications, respectively) here are two example of the prevailing sentiments - from a thread at that site:
Example A: Greg's SKOptVol is actually better (and cost less) than the passive Ladder Volume switch that I was using 😎 With Greg now using a 27K series resistor, the minimum volume is -54.5db 🙂 My Speakers are 92db and -54.5db is sufficient for them. Here's what I wrote a few months ago about Greg's SKPre c/w SKOptVol ... Quote: Hi All I have just completed an SKPre c/w SKOpticalAttenuator and thought that I would give a short report on it. This is a very transparent and neutral preamp. The stage is very open, deep and wide. It is very musical and detailed. The highs and mid-range are very detailed and have no edge to them. The bass is very detailed and full, also. Everything has a very "there" feel to it. Nothing seems to stand out or be out of place ... very nice Also, the SKOpicalAttuator is also very good sounding ... 🙂 Actually, I would say that Greg's SKOptVol is fantastic and will be my choice of volume pot in the future 8- ) :thumbsup.
Example B: Title: Re: Simple LDR volume control! Post by sfox52 on Apr 5 th , 2008, 11:06pm Me Three! 😉- I shoehorned my Optivol into a Bottlehead Foreplay Tube linestage pre-amp, powered via a wallwart dc supply. It's the best attenuator I've had in it, including a stepped switch!.
Far-be-it from me to advocate any particular means of volume-control. I embarked on this venture with a view to finding an upgrade for a noisy pot in my own pre. The result is that my choices have now been short-listed to a few probable candidates. I've posted my findings with the hope that this will assist others who're engaged in a similar quest (and, with a similar aim, these findings will also be incorporated into a revised version of a recent article at my little site linked below). That's it!
Thanks to all who participated, for the most part. This forum is great!
Peace!
____________________________
WAJ on AUDIO
I posed this question elsewhwre, but perhaps this is the right place for it. Some audiophiles seem to feel that stepped-attenuators (DACT etc) thin-out the lower-mids. A poster here relates that; in past he's tried stepped attenuators, ladder type, with metal film resistor. Compared to common cheap carbon pot (like ALPS and some TKD) the sound of stepped was somewhat clearer, better soundstage, but overall the carbon pot sounds better, more musical, more natural.
Others, elsewhere go further to claim that the atts' clarity border on 'edginess', made more obvious by the atts thinner mids, compared to carbon pots, and other forms of volume-control.
Has anyone else here experienced this? And is there any stepped attenuator which actually sounds 'full', in the lower-mids?
I use a TKD stepped attenuator in my AKSA preamp. This is the same one selected by the late, great Bob Crump for the "Blowtorch" preamp.
No thin lower mids, I can assure you - obviously those posters who said this, hadn't bothered to try the TKD. 😉
Regards,
Andy
Regards,
Andy
My sentiments too - to an extent. Been leanin' towards that said TKD meself. Lamm uses it in the LL1, Audio-Note too, and we all know about the Blow-Torch - no reports of thinness in the mids of either of these pre..s. But this is the reason I worded that segment as I did. I'm reasonably convinced that this is a concern with at least one or two over-the-counter atts (including the DACT), but people have a tendency to generalize, inadvertently clouding the issue. I simply reported what I found, as I found it, leaving people to interpret for themselves and further investigate because, as I said, this segement of my own research was inconclusive - to this moment, at least - for the reasons cited. (The samples of opinion were not just from this forum, btw, but from a wider cross-section of available opinion).
Oh, and you're right, of course, Bob Crump is the one who did the att research (re; my post #37) not sure how John Curl became mixed-up in my brain. Perhaps this is because he's also associated with this pre - I think.
Thanks!
WAJ on AUDIO
Somewhere around post 5000 on the current blowtorch site I posted resistor distortion measurements. They show carbon comp, carbon film and various others distortion. It may shed some light on what people claim to hear. I am too lazy to look up the exact post numbers.
If the topic seeks to establish whether atts display a thinner sound, then this implies that other means of volume-control are not so afflicted. If pleasant harmonic-distortions (or whatever other reasons) account for a 'fuller' sound from carbon pots/resistors and LDR (or even TVCs, for that matter) compared to that of atts, then I'd have imagined that this'd be relevant to the topic - in some sense - since atts do not exist in a vacuum, there are alternatives.
My original post included this sentence: 'Others, elsewhere go further to claim that the atts' clarity border on 'edginess', made more obvious by the atts thinner mids, compared to carbon pots, and other forms of volume-control.' I may very well be intellectually-challenged, but I fail to see how pots can be relevant to this debate, while TVCs and LDRs are not - all are forms of volume-control, to my understanding, though all can be utilized as the main components in passive pre..s. From my perspective, I've no interest in passive pre..s (been there, and done it - and done with it).
Unfortunately, in the context of this thread, perhaps some only view TVCs and LDRs as passive pre-amps - hence, the call for a separate thread. I see them differently (indeed, a reflection of the reality) in the context of their use as volume-controls in active pre-amps, such as Coincident (TVC) and darTZeel (LDR) along with countless other diy active pre-amps, and upgrades to existing active pre..s (as is my intent with my own active pre).
Therefore, in the context of their use as volume-controls in active pre-amps, any concerns with atts would necessarily be considered against the alternatives (as my OP indicates) including carbon or plastic pots, TVCs, and LDR volume-controls - not passive pre-amps.
Perhaps I'm wrong!
.WAJ on AUDIO
Yes, I see those all as well within the scope of your original question. Especially as a reference to the sound of the stepped attenuators. What does a S.A. sound like in comparison to X,Y or Z? Not off topic.
