I have seen those small 50 watt 120v to 240v transformers floating around, and I have often wondered if that sould be used to power the B+ of a small preamp. 240v*10mA=less than 3 watts, so I dont see why power-wise it would not work. I don't know if they are current-isolated from the mains, but I was hoping someone here might have some more info.
They are usually autotransformers so not suitable.
Check for continuity between the 110V tap and the 240V tap.
Shoog
Shoog
Is that a conventional power xfmr? I used to use something that small for a bias supply.
I guess it would be OK for class A duty. The steady current requirement (especially if used for a class A preamp) would draw little problem from the potentially bad load regulation characteristic of the xfmr. I would probably want a substantial filter capacitance and only ask a few mA from it.
lndm said:Is that a conventional power xfmr? I used to use something that small for a bias supply.
That is what I figured. I am thinking of experimenting with one running a single 12ax7 tube for the preamp and a 12au7 output buffer, so I would not be drawing more than half a dozen milliamps.
I have seen a few advertised as "isolated" so I suppose they would work.. maybe I'll get a few and see which are autotransformers and which ARE actually isolated.
I usually like to run regulated voltage in my preamps anyway, so I am not overly concerned with poor tranny regulation.
I have found that the cheapest way to get 240VAC is a Triad N-68X. $11.20 at Mouser and it is good for 50 watts. It has 2 115 volt primaries and 1 115 volt secondary. Turn it around (use the secondary as a primary) and you have a 230 volt center tapped secondary. with a FWB rectifier I get almost 300 volts DC at over 100 mA. They also have a 6.3 VAC 3 amp filament transformer (41FD030) for $6.98.
So you have the power supply iron for $18. With the Edcor $18 output transformers I have all of the iron for a good sounding SE UL amp for $54!
tubelab.com said:I have found that the cheapest way to get 240VAC is a Triad N-68X. $11.20 at Mouser and it is good for 50 watts. It has 2 115 volt primaries and 1 115 volt secondary. Turn it around (use the secondary as a primary) and you have a 230 volt center tapped secondary. with a FWB rectifier I get almost 300 volts DC at over 100 mA. They also have a 6.3 VAC 3 amp filament transformer (41FD030) for $6.98.
that's a great tip. Thanx. I have to do a Dale resistor order @ Mouser anyway, so I may as well toss one of those on.
- Tubes / Valves
- step-up travel transformer for small preamp?
