Stax drivers foil repair
Hi, found a stax omegas2 to have a holes burnt in foils. Weirrd thing is, holes are not in center, but offset.....😕 about 5mm diameter-stators have there dark color.
How to proceed? I guess original bias rings with foils are not to be sold separately. Or maybe expensive.
I read a few threads about those drivers, some people after trial and error making it happen.
Found in local shop a mylar sheets 5microns, clear or metallised (scratchable with fingernail) Which one is better for transducers?
Your opinions?
http://www.kontaktchemie.com/KOC/KOCproducts.csp?CSPToken=J4R8h8TBbLP_6e6tHYLe$YCrAXOj3Oju5thdO23Vtpo-
https://translate.google.sk/transla...-Mylar-folia-cira-6-8-g-m2&edit-text=&act=url
https://translate.google.sk/transla...Potahovy-material/5/2692-MYLAR-folia-pokovena
clear is better 🙂 but for headphones maybe thinner is even better , you cna order 1 3 6 on ebay look for esl mylar or electrostatic mylar. buy a decent coating like licron crystal. and off you go. before you tear the old ones check if you can figure out what the resonance is.
The thinest I have ever obtained is 1.5um (.06mil) polyester, stock #90 from Chemplex. 🙂
I also have some 2.5um (.10 ml) Mylar stock #100 that I made my Micro ESl out of.
http://www.diyaudio.com/forums/planars-exotics/158115-material-esl-2.html#post2076459
It worked great and I used heat for tensioning.
http://www.diyaudio.com/forums/planars-exotics/233008-esl-hybrid-2.html#post3768538
Their stuff only comes in 2.5" and 3" widths.
I used licron for my coating.
Thin Film Selection Guide - Thin Film Selection Guide - Thin-Film | Chemplex Industries, Inc.
jer 🙂
