I own a Hot Rod Deluxe 1VTm Fender. Recently it started emitting static noise when guitar is plugged in. Noise would increase with volume. I would appreciate any help on the problem and how to fix it.
Welcome to the Tubes / Valves threads.
Thanks for telling us in Post # 1 that this is for a guitar amplifier . . . I appreciate it.
Did you try a different shielded cable?
Did you try a second guitar?
Someone on the Instruments and Valves threads has probably already experienced your problem, and fixed it.
