Starting bruteFIR automatically
I spend all day setting up a Pi Zero W with shairport-sync and bruteFIR. It works fine using the alsa loopback method, but I still have to start bruteFIR manually. This is my unit file, is there anything wrong?
Code:
[Unit]
Description=BruteFIR
[Service]
ExecStart=/usr/bin/brutefir /home/brutefir/brutefir_config
Restart=on-failure
RestartSec=1
[Install]
WantedBy=multi-user.target
Some ideas.
Do you want to run it as user brutefir ?
Once you start brutefir it'll look for the default config in ~
In your case it would be /root
But I guess you'd have it in /home/brutefir
IC 2 potential ways out.
Either you add all config parameters to your customized config and start brutefir with
"-nodefault" . Then you can run it as whatever user. The paths references in the customized config file must be accessible though.
or you add e.g.
Code:
[Unit]
[Service]
User=brutefir
Group=audio
Restart=on-failure
RestartSec=1
[Install]
As far as I recall running brutefir standalone with aloop doesn't work. brutefir needs an audio input.
Perhaps you also need to add
After=shairpoint-sync
if shairpoint-sync would be a service.
shairport sync would then keep brutefir alive.
All just some wild ideas. I might try to set it up myself on a PI4.
Could you share your config?
Let us know if and how you made it work.
Still doesn't work, I have to login and restart the brutefir service, then it works. Posting my full config below.
/etc/systemd/system/brutefir.service:
Code:
After=shairport-sync.service
[Service]
User=brutefir
Group=audio
Restart=on-failure
RestartSec=1
WorkingDirectory=/home/brutefir
[Install]
/etc/asound.conf:
Code:
# Run the following commands as root to load the ALSA loopback-device on boot automatically:
#	echo 'snd-aloop'								> /etc/modules-load.d/brutefir-alsa-loopback.conf
#	echo 'options snd-aloop id=BruteFIR enable=1 pcm_substreams=1 pcm_notify=1'	> /etc/modprobe.d/brutefir-alsa-loopback.conf
# Create an ALSA default audio-device for the ALSA loopback-device.
pcm.!default {
    # Use the ALSA plug-in "plug" for rate-/format-conversion.
    type plug
    # Forward the audio stream of OSMC/KODI to the ALSA loopback-device
    slave {
	pcm {
	    # Direct hardware access
	    type	hw
	    # Loopback card name
	    # Has to match "id" in the options of the snd-aloop module
	    card	"BruteFIR"
	    # Loopback device ID
	    device	0
	    # Number of audio channels
	    # Has to match the number of channels in OSMC/KODI (e.g. 7.1 -> 8)
	    # and "channels" in the BruteFIR input configuration
	    channels	2
	    # Format of audio stream
	    # Has to match the format defined in the "sample"-tag
	    # of the BruteFIR input configuration
	    format	"S16_LE"
	    # Sampling-rate of audio stream
	    # Has to match the sampling-rate defined in the global "sampling_rate"-tag
	    # of the global BruteFIR configuration
	    rate	44100
# Create an ALSA default control-device for the ALSA loopback-device.
ctl.!default {
        type	hw
        card	"BruteFIR"
/home/brutefir/brutefir_config:
Code:
## DEFAULT GENERAL SETTINGS ##
float_bits: 32;             # internal floating point precision
sampling_rate: 44100;       # sampling rate in Hz of audio interfaces
filter_length: 8192,16;       # length of filters
#config_file: "~/.brutefir_config"; # standard location of main config file
overflow_warnings: true;    # echo warnings to stderr if overflow occurs
show_progress: false;        # echo filtering progress to stderr
max_dither_table_size: 0;   # maximum size in bytes of precalculated dither
allow_poll_mode: false;     # allow use of input poll mode
modules_path: ".";          # extra path where to find BruteFIR modules
monitor_rate: false;        # monitor sample rate
powersave: true;           # pause filtering when input is zero
lock_memory: true;          # try to lock memory if realtime prio is set
sdf_length: -1;             # subsample filter half length in samples
safety_limit: -0.01;           # if non-zero max dB in output before aborting
convolver_config: "~/.brutefir_convolver"; # location of convolver config file
## COEFF DEFAULTS ##
coeff "c-l" {
#   filename: "/home/brutefir/Cor1L44.dbl";
   filename: "dirac pulse";
   format: "FLOAT64_LE";
coeff "c-r" {
#   filename: "/home/brutefir/Cor1R44.dbl";
## INPUT DEFAULTS ##
input "left_in", "right_in" {
        device: "alsa" { device: "hw:BruteFIR,1"; ignore_xrun: true; };
	sample: "S16_LE";
	channels: 2;
## OUTPUT analog
output "left_out", "right_out" {
        device: "alsa" { device: "hw:2,0"; ignore_xrun: true; };
	sample: "S16_LE";
#	dither: true;
## FILTER DEFAULTS ##
filter "drc_l" {
   from_inputs: "left_in";
   to_outputs: "left_out";
   coeff: "c-l";
filter "drc_r" {
   from_inputs: "right_in";
   to_outputs: "right_out";
   coeff: "c-r";
Have you enabled the brutefir.service with systemctl?
That was it, goddamnit, thanks!
I didn't manage to run brutefir as non-root, it wouldn't start despite adding "LimitRTPRIO=infinity", and with that it wouldn't run as realtime which doesn't work. I also didn't manage to start the service via shairport using the "run_this_before_entering_active_state" directive, but luckily I don't need that anymore.
