I think a more modest plan is called for.
Most computer power supplies can't put out enough juice to accomplish something as ambitious as 400W. Furthermore, they generally top out at 12VDC positive and the negative 12VDC (if any) is generally pretty limited current-wise. The 5V is pretty useless unless you want to run a few relays or something like that.
If you were fortunate enough to have a reasonable amount of current available on the -12V supply, you could build a Mini-A or something along those lines. However, the difference between your goal and reality will become obvious when I drop in the datum that the Mini-A is a 10W amplifier...and that's assuming +-15V rails, not +-12V. With 12V rails you'd be looking at something on the order of 6.5W.
I stubbed my toe on a computer power supply today and turned it over to look at the ratings. I believe it was 7A at +12V, but only .39A at -12V. And that was a fair-sized power supply.
Your best bet would be to consider finding a car amplifier that draws some amount of current that your power supply can reasonably be expected to supply.
You'll run into a few problems:
--Car stuff generally just doesn't sound that good. Loud? Yes. Quality? No.
--Stay well within the current ratings of your computer power supply. If you get too close to the specified output, you may blow the power supply.
--Computer power supplies--just by the nature of the way the way they work--tend to provide power that isn't exactly suited for hi-fi use. It's heavily laden with switching transients. They're designed with efficiency in mind, not fidelity.
You can probably pick up a car amplifier cheap in a pawn shop or perhaps off of e-bay. That would give you a comparatively cheap way to experiment with your power supply.
Grey
