Starsound d2500 power supply problem
Hi guys im currently busy doing a power supply repair on a starsound d2500 2 channel amp i replaced the tl494 ic took out buffer transistor and fitted bd 139 and bd 140. Without power supply fets the drive looks good nice and square but when i fit fets it changes drasticly I'll post pics of the drive later. It has in 47ohm resistors on the gates and 220ohm pull down resistors I also removed the rectifiers to isolate power supply from output section the power supply fets are Irfz44n
Hi Perry it doesnt heat up but what happens is when i turn on the amp the green light comes in very slow and when the amp plays it dies down and struggles to get back on. I have to turn volume down for the amp to recover thats why i decided to re do power supply
This is the drain of power supply fets wave
