In this thread I'm going to document another 'quick and dirty' project of mine.
Here are the goals of this project:
1) Good phase coherency. I think this is important as it improves articulation. And when you improve articulation, voices are easier to understand, percussion sounds more realistic, and it seems to reduce listener fatigue.
2) One of the odder aspects of this project is that it will have two stereo channels in one enclosure
3) Efficiency should be a bit higher than normal. As usual, it's going to be horn loaded.
Some of you may have noticed that the titles of my threads usually have nothing to do with the speaker that's documented. The reason that I do this is that it makes it really easy to look up old projects. (It's a lot easier to remember the name of a thread like 'Square Pegs' or 'Sunshine' than Twelve Inch Woofers In My Dash - CARSOUND.COM Forum)
The name of this thread is a tip of the hat to Eugene Jarvis, one of my computer programming heroes. In an interview (Eugene Jarvis) he talks about how Stargate was an evolution of Defender. This project, obviously, is an evolution of some of my loudspeaker projects. BTW, the interview is lulz, here's one of my favorite quotes:
"After "Defender," Williams' first video game, came out and was such a huge hit, management decided that if one team could design a huge hit, 100 teams could design 100 hits. It was basically the monkey and typewriter approach to game design. So a huge new facility was constructed--Kedzie--with a beehive of offices. Since the edict went out to staff up quickly, an army of warm bodies were hired. Whereas I designed "Defender" in an abandoned factory in complete isolation, now I was subjected to twenty stereos playing "Disco Duck," all the while gagging on Cannabis fumes from the turned-on masses."
(I'm a programmer in my day job, so I find Jarvis' observations about the tech world amusing.)
'stargate' is basically a VTC Paraline, sliced in half.
this is a Paraline
This is a stargate. I'm only showing one half of it; in my car it's mirrored, with two stereo channels in a cabinet that's about 50cm wide.
In the pic, we see the following:
1) it's a Paraline sliced in half
2) There are two reasons that it's sliced in half:
a) a Paraline gives you narrow directivity in one dimension, and wide directivity in the other. For instance, it's possible to get directivity that's close to 180 degrees in one dimensions, but zero degrees in the other. This is handy for 'underdash horns' where we want narrow vertical directivity to reduce reflections off the car doors, but wide directivity to allow the horn to be placed a couple feet lower than optimal. (Optimally, it would be at ear level, on the dash.)
b) my 'stargate' has two stereo channels in one chassis, so we want very narrow directivity to keep the left from 'bleeding' into the right
this is a Paraline
some pics of it coming together:
I printed the stargate on my laser printer. Basically just print it, then copy it to the plywood horn
My girlfriend says it looks like a pair of boobs
It's about an inch thick
My favorite way to line up the throat of a horn. A plexiglass mounting plate. Thanks to Geddes for the idea.
Here's a pic of the device, to give it some scale. Those are 5cm midranges.
Been watching all things Unity, Synergy, Paraline for a few months now. I am very interested in this build. I always look forward to your post, there is always something special happening in your builds. I often wonder if I think about all these ideas, what type of information overload your brain must stay in!
Revolution!
Steve
Revolution!
Steve
But the Headphone sized drivers of clearly inexpensive mfg Don't seem promising or even IMO worth the effort of even chopped up door skin ply.
We know, we know... nothing less than a 15" Tannoy can possibly do the job.
dave
Interesting notion. But the Headphone sized drivers of clearly inexpensive mfg Don't seem promising or even IMO worth the effort of even chopped up door skin ply.
Probably one of the trickiest challenges in a Unity horn is getting the woofer to mate up with the midrange. If your mid is too big, you get a trough in the response around 1500hz. (Check out the thread 'suitable midrange for unity horn')
That leaves a couple options:
1) use a big compression driver and cross over low
or
2) use very small midranges
I prefer option 2. If you use a 'conventional' compression driver, it tends to roll off around 16khz, and I prefer the 'sparkle' you get with smaller compression drivers like the CDX1-1425
If you have the space, option 1 is perfectly viable.
Unfortunately, this opens up another can of worms, which is that you need a larger internal height in the Paraline, which rolls off the highs. (Which are *already* rolled off due to the choice of a larger compression driver.)
Long story short, I like option two.
Here's some more pictures of stargate
Overhead view of the device
The very wide vertical dispersion is due to the VERY narrow vertical mouth. Just one half of a centimeter. The big black plastic roundover is there to reduce diffraction at the mouth. The reason that it's only rounded on one side is that it's designed to be placed in a car, where the dash extends the curve on one side, but not the other.
This is the on-axis response of the device
My measurement technique isn't terribly sophisticated; this was measured using the RTA on my iPad, on axis, at approximately 2 feet. Levels are fairly low as I didn't want to blow up the compression drivers. (There's no xover in the mix.)
This is the same measurement, at 45 degrees off axis. Note how similar it is to the on-axis response. (Ideally we'd want the exact same shape, but at a reduced output level.)
The two graphs overlayed.
Not too shabby huh?
Not too shabby huh?
What's so good about 15" Tannoys anyway?We know, we know... nothing less than a 15" Tannoy can possibly do the job.
dave
- Stargate
