stAMP final version
I've now finally settled on a version of my stAMP that I'm totally happy with.
Few changes from before...
-ATtiny9 on board for turn on delay. Also has a LED that turns on when the delay is complete. When the amp's fault flag comes up, the LED flashes.
-Bigger input caps (4.7uF)
-Differential inputs available, and can be disabled with a jumper.
-Gain selectable with a jumper, either 20dB or 32dB.
-Limited to 42W max this time, to prevent thermal issues.
Available from my shop. More info in the vendors section: http://www.diyaudio.com/forums/vendors-bazaar/265881-some-more-really-small-amps.html
