Stacking a toroidal PT over a toroidal choke
Working on laying out a little tube amplifier and decided on trying to use one of the Antek toroidal chokes. From a packaging standpoint, I'd love to put the PT (in a case) on top of the chassis with the choke mounted directly below it. I'd probably never consider mixing signal and PSU based toroids on top of one another, but curious what you all think about a choke? I'm not coming up with any significant concerns but would love to hear from the experts on this page. Thanks in advance!
I took the OP to mean that the PT will be on top of the chassis plate and the choke will be below it. Am I correct?
That is correct. Using one of the Antek steel covers on top of the top plate. And will get a longer screw to secure the choke to the same assembly. I can certainly plan on building a little space in between, anyway. It would be very simple. I don't expect there too be too much concern with heat, it's a little spud amp using 6T9s and I'm definitely over doing the PSU.
