1pair of 200W devices can manage about 120W into 4ohm at a phase angle of 60degrees and Tc<50degC.
But into 2ohm can only increase to about 150W and at a phase angle of 42degrees, so this is your limit.
To achieve these powers the voltage amplifier will need extra PSU voltage above the +-42Vdc you are planning.
lineup said:
Package is TO-247, the 200Watt version of this MOSFET
As, also, I wrote in my post with short DATA for this device
in my post above
the thermal cooling factor is 0.75 C/W
and the Ciss is 4000-5000pF, which certainly is worth to consider!
Hmm...Ciss is high indeed. Zox2003 if you are going to use my cct then you should increase the drive current for the final stage. You can do this by lowering the value of R22 & R20 to 150 ohms. This lowers the impedance and will better manage the FETs combined Ciss. Note only for 40 - 50 volt rails.
Cheers
The schematic I am refering to is here: http://www.diyaudio.com/forums/showthread.php?postid=1008216#post1008216
For rails under 50 volts R6 should be replaced with a link.
Q
Q
AndrewT said:Have you bothered to follow the links in post12?
that is what i wonder, too
quasi
in a post here above
does refer to some of his circuits, which could be used if you change some resistors
to possibly be able to drive those transistors of yours
Anyway
here is the latest version of a powerful quasi N-Channel design
PDF schematic attachment in Post #1123:
http://www.diyaudio.com/forums/attachment.php?s=&postid=1008216&stamp=1158583789
Post #1123:
Topic:
Power amp under development
lineup
Surprisingly, possibly quite a long time if appropriate heatsink is used. I worked for a company making high quality pro audio gear, and we used a single pair for our 125W/4R MOSFET amp. They were only rated at 125W whereas these are rated at 200W. I've not compared the SOA graphs for each but I'd expect them to be similar.
We did have VI limiting which no doubt helped save these amps from destruction, but it just goes to show.
richie00boy said:We did have VI limiting which no doubt helped save these amps from destruction, but it just goes to show.
And a BIGGER heatsink will also be important!
Two pairs= 4,
and each transistor takes 25% of the cooling power.
One pair = 2,
and each transistor will have remove twice as much heat per transistor
at equal output power level.
4 transistors will have lower thermal resistance, than only 2.
This is how many degrees the transistor inside temperature will increase per Watt.
Measured in C/W, degrees C per Watt.
- ST MOSFET-Power Amplifier use???
