Salas I want to tell you a mystery when I bring the screwdriver over and without touching the trimmer the voltage lowers two votios, when I remove the screwdriver the voltage returns to raise two volts. Exactly when the screwdriver is near 2 cm lowers 1V, less of 2cm lowers 2 volts.
I haven't met that condition in a bib before. Is it a magnetic screwdriver?
Voltage also change using plastic screwdriver, also I think I have problems with CCS because set resistor 22R (I guess is too high resistor value) / 9.73V = 441mA, the load idle draws 130mA x 1.5 safety for peaks = 195mA + 70/150mA excess on top load = 345mA but in this moment I don't have other higher value of 10W resistor, I use 30VAC 30VA R-Core, 10.000uF 63V mains cap & IRF9610.
I had a little time this afternoon and have, I think, finalised the setup and installation of my Salas BIB positive/negative supply pair.
I took AndrewT's point about transformer voltage and I've backed down the output voltages to 13V.
Everything seems very stable.
Back to the 'I think' comment; should I worry about a mismatch in the shunt current? On the negative supply I'm measuring 2.6V across R201, which equates to 382mA. On the positive supply I'm measuring 2.9V across R101, which equates to 426mA.
I'm measuring the supplies separately using exactly the same 47R load resistor (287mA load).
The circuit I'll be powering with the supplies is a 350mA load.
A 56R in parallel with R201 should more or less equalise them at the higher current if I need to balance them more closely? The mosfets have good heatsinking.
R101/R201 are both 4watt 6R8, am I correct in thinking that any parallel resistor can be of low power rating?
Thanks muchly
Ray
Thanks muchly
Ray
- Power Supplies
- SSLV1.1 builds & fairy tales
