Please let me know if you have any questions about this board. I have one of these at my studio in Orlando, FL. East Rom Suites It is by far one of the best consoles for a small studio footprint. It is definitely an amazing bridge between analog and digital.
The Standard information:
- 32 x 16 x 16 'Insert Router' for up to 16 external hardware processing devices
- Hardware processors can be inserted via console controls or cross-platform drag-and-drop software browser
- Stereo or 5.1 EXT monitoring outputs with independent Main and Mini monitor control
- Hardware processors can be inserted individually or as 'chains'40 input Super Analogue summing console
- Stereo Aux Send and 4 x Mono Sends per channel
- 4 Stereo Returns with full stereo mix bus routing
- Dual Stereo Mix Busses with summing Inserts and reassign In Line' DAW monitoring with 'SuperCue' headphone mode
- Stereo or 5.1 External Monitor inputs
- Stereo digital I/O (S/PDIF, AES/EBU) with SSL converter technology
- iJack front panel Monitor input
- Heavy-duty external PSU16 analog line channels with two inputs per channel
- Artist Monitor output with independent EQ and monitor source selection
- Single button push flips control between the analog signal path and DAW software
- Multi-layer control of up to four DAWs simultaneously
- Ergonomically advanced hybrid hardware control surface
- Digital scribble strips for constant visual feedback
- Fader-linking for analog channels
- Additional motorized 'Focus' fader for simultaneous DAW/Console control
- 16 channel strips each with motorized fader and assignable rotary encoder
- Total Recall for analog console controls
- General purpose MIDI controller mode
- A-FADA or MIDI Fader automation
- Ethernet MIDI connectivity
- Simple drag and drop insert router page for configuring hardware device chains and loading inserts
- Intuitive cross-platform remote browser for system configuration and project management
- Cross-platform 'Logictivity' remote browser interface
- Programmable hardware buttons for sending standard USB keyboard commands
Lacks AI? Do you mean like a real human wrote this thread? That is because a real human wrote this.
