SSE Weak/Fuzzy Right Channel
I built up an SSE a few years ago, listen to it daily and really love it. About a week ago it started getting a really weak quiet right channel. Swapped the power tubes and put in different tubes, no change. Opened it up and look for loose connections, or anything showing obvious damage, but could not find anything. Does anyone have any recommendations for starting to trouble shoot with the multi-meter? Any suggestions appreciated, thank you!
If you just record all the voltages to ground on all the pins, and post them here, that should highlight an electrical issue. Other wise it could be a connection - RCA input, speaker, so a poke with a plastic stick sometimes pays dividends.
That description is pretty vague.
You can swap the left input to the right input, and see if that restores proper operation. If so, the problem is not in the SSE.
A bad cathode bypass capacitor will significantly reduce the gain of the affected stage.
Win W5JAG
